craer's avatar
craer
Backup home folders on ReadyNAS 528X using replicate
  Finely i am able to get a real backup solution set  up using my old ready nas's,   after losing most files when readycloud went down this yea.... i am trying to get home folders (where i put most...
  • StephenB's avatar
    Aug 08, 2017
    craer wrote:
    i dont know if the router where the remote nas will be has a dns on it. (YET)
    cause i would rather push if i could chouse.
    To be clear, you want DDNS, not ordinary DNS.  If the router doesn't support it, you can also install a DDNS client on a PC in that location.
    craer wrote:
    i am using the moth on INT ips so exp:192.168.1.10 for Nas A and 192.168.1.20 for Nas B
    not sure if i nead to open the port 22 when i get it working on Int IP and more it over to
    EXT IP ( over the internet)
    Of course test the backup job on your local network.
    Later on (for push) you will need to replace the IP address for NAS B with the DDNS name.  And you will need to forward port 22 on the router for NAS B.
    craer wrote:
    did you see and thing else i did wrong on any other  part of the setup? such as the shair ?  its a shair strait off the main root Data/(share name)
    Again, getting the backup(s) working on the local lan will flush out any mistakes in the backup job settings.  In general, you will need rsync enabled for the destination share(s) on NAS B.
ProSupport for Business
