rodcrit
Oct 28, 2017Luminary
backups from pc failing after upgrade
after installing the upgrade 6.9.0 my backups from my PC no longer work the backups ( 15 of them ) all start and remain in the " in progress" state. in previous version they remained in the " in...
- Oct 30, 2017
For anybody experiencing an issue with backup jobs remaining in "in progress" on SMB timestamp backup jobs, we have posted a hot-fix to resolve that issue, and your system should be automatically updated some time in the next week. If you'd like the receive the update immediately, you can reboot your NAS and it should be updated within 15 minutes.
Kimera
Nov 04, 2017Guide
Ltrein: I suggest you to read this whole thread (at some point of the thread, there is the Netgear's explanation WRT the interaction between new ReadyNAS OS 6.9.0 software version and Veeam which causes the issue you're experiencing).
ahdvd
Nov 14, 2017Aspirant
I've seen several of these posts suggesting that 6.9.0 is not working properly for the backup function as well as my own post about ReadyDLNA now no longer working, I wish they would fully test these or at least include a roll-back option with these allowing us to go back to the previous version if faults like this are found.
