david2010
Oct 12, 2015Tutor
Can't update 102 to firmware 6.4.0
I have tried using the NAS webpage (FIREFOX) to auto update and also a manual update of downloaded firmware without success. The unit uploads the image and prompts a reboot to install yet it doesn't...
BrianL2
Nov 01, 2015NETGEAR Employee Retired
Hi EnLa,
Try the workaround posted in this article and let us know what happens.
Kind regards,
BrianL
NETGEAR Community Team
EnLa
Nov 07, 2015Aspirant
Hi BrianL,
what is the difference between the workaround of your link and the workaround of the link I have reported not working for me? They are both pointing to the same workaround, so I assume you have overlooked the link I provided with my previous post.
Any other idea?
Thanks,
Enno
- StephenBNov 08, 2015Guru - Experienced User
You can contact support via support.netgear.com.
Maybe PM kohdee first.
