ipb_uk
Feb 19, 2018Aspirant
CPU fan speed stuck at 4218rpm
Hi, The CPU fan seems to be stuck at 4218 & 3515 rpm. Not sure how long it's been like this but at least a week. Room temp = 23c CPU = 45 System = 55 Disk1 = 38 Disk2 = 38 Disk3 = 37 Di...
ipb_uk
Feb 20, 2018Aspirant
Contents is......
chip "colabel temp2 "CPU"
compute temp2 @%35, @%35
ignore temp3
chip "w83627dhg-isa-*"
label in1 "DDB18"
set in1_min 1.62
set in1_max 1.98
set in2_min 3.3 * 0.90
set in2_max 3.3 * 1.10
label in3 VCC3
set in3_min 3.3 * 0.90
set in3_max 3.3 * 1.10
label in4 VCC1_25
set in4_min 1.17
set in4_max 1.32
label in5 "VCC1_5"
set in5_min 1.41
set in5_max 1.58
label in6 "VCC1_05"
set in6_min 0.98
set in6_max 1.10
set in7_min 3.3 * 0.90
set in7_max 3.3 * 1.10
set in8_min 3.0 * 0.90
set in8_max 3.3 * 1.10
label fan1 "System"
set fan1_min 600
label fan2 "CPU"
set fan2_min 150
label fan3 "System"
set fan3_min 600
ignore fan4
ignore fan5
label temp1 "System"
set temp1_max 80
ignore temp2
ignore temp3
ignore cpu0_vid
ignore intrusion0
Supertramp11
Feb 20, 2018Luminary
I ran 6.9.1 and currently run 6.9.2 on my PRO 6 coming from 6.5.0 and I have to say that the fans never worked better than with 6.9.x.
This is not an immediate help to resolve your problem, but I thought I share this.
