jwilkinson84
Dec 06, 2018Aspirant
External hard drive format recommendations
I am trying to connect an external hard drive into the eSATA port in the back. I have tried to format the drive with NTFS, but the ReadyNas doesn't see it. If I connect it using a USB setup i get the...
Retired_Member
Dec 06, 2018Hi jwilkinson84, just use your windows workstation to blank the disk (no formatting, even no partition) and reconnect it to the nas after that. Then check again, whether you can format it.
jwilkinson84
Dec 07, 2018Aspirant
Tried that as well and the NAS doesn't see it ether using eSATA or USB cable.
- Retired_MemberDec 07, 2018
Hi jwilkinson84, to find out, whether nas or disk or cable is the problem I would suggest to
1) use a disk where you know, that it works
2) use a cable where you know, that it works
3) use another nas, if available to check connectivity
Combination of all three options should give you enough info to draw your conclusions, whether the disk is broken or incompatibel, you might have a problem with your cable or the nas itself is causing the issue.
Kind regards
