obaeyens
Oct 07, 2015Aspirant
Firmware 6.4.0 on ReadyNas 104 (orange blinking network led)
I do not recall the orange blinking led yet on my ReadyNas 104 with the previous firmware. I swapped the cable with the 204 (previous firmware) but it stays orange blinking while the 204 shows gr...
JennC
Oct 08, 2015NETGEAR Employee Retired
Hello obaeyens,
Green off, amber blinking means 10 Mbps or 100 Mbps connection speed, this depends on the LAN port on the router/switch where the NAS is plugged in. If the router doesn't have gigabit ports then the NAS will not get gigabit speed.
Like StephenB mentioned, check the router. You may also try testing the other LAN port on the NAS since there are 2 LAN ports on it.
obaeyens
Oct 08, 2015Aspirant
Wel that is the interesting part. It was green before the 6.4.0 firware upgrade.
I have a 104 and 204 connected to both the same 1 GB switch.
I swaped both 104 and 204 cables the amber persists and I even tried the other network card, it stays abmber.
I only saw this after the v6.4.0 firmware update on the 104. Nothing else changed.
For me it is not a breaking issue, but it indicates something in the firmware 6.4.0.
- StephenBOct 08, 2015Guru - Experienced User
And what does your router say the link speed actually is?
If you have ssh enabled, you can also confirm the link speed on the NAS.
- JennCOct 08, 2015NETGEAR Employee Retired
Hello obaeyens,
How about the RN204 NIC led?
Have you also already tried on another NIC of the RN104?
- shydoodyOct 08, 2015Aspirant
Same here.
After upgrading ReadyNAS104 to 6.4.0 the LED's are blinking orange.
Transferring Data to PC is about 850 MB/s anyway, so it's GBit.
I think, here are just the wrong LED'S adressed.
After ugrading my ReadyNAS314 to 6.4.0, here it's blinking in green, as before (6.2.4).
- obaeyensOct 08, 2015Aspirant
The switch at Netgear GS108 has 2 green LED's, but the 104 has this left amber right green.
The interesting thing is that on the 104 the blinking led is on the left (which is amber) while on the 204 the blinking is on the right. (seen from behind).
Now that I notice the NAS network adapter web page has Eth0 on the left side for the 104, while the 204 has the eth0 on the right side. So the upper connector is upside down compared between them.
Someone flipped a bit ;-)
