obaeyens
Oct 07, 2015Aspirant
Firmware 6.4.0 on ReadyNas 104 (orange blinking network led)
I do not recall the orange blinking led yet on my ReadyNas 104 with the previous firmware. I swapped the cable with the 204 (previous firmware) but it stays orange blinking while the 204 shows gr...
Oct 09, 2015Guru - Experienced User
obaeyens wrote:
The switch shows 2 green leds which suggest me that it is a wrong bit set to the 104 NAS and incorrectly shows an orange LED instead of a green.
If you are saying the leds are simply wrong, then you could well be right.
One way to check is to test the NAS read/write speeds. You could use nastester for that http://www.808.dk/?code-csharp-nas-performance. RN104 read speed is normally ~70MB/s and write is ~50 MB/s - over gigabit ethernet.
obaeyens
Oct 09, 2015Aspirant
Just tested
The Write 45 MB/s
The read 40 MB/s
However these are older recycled hard disks!!!!
The fact that I can read and write at this speed means that I at least have 100 Mbs and thus is the amber LED incorrect and should be green.
