harryrichardfoe
Jun 06, 2017Guide
Re: Firmware update 6.7.4 Issue
Hello, I upgraded from 6.6.1 to 6.7.4 yesterday and now have an issue with the USB external drive disconnecting at random intervals. The drive reconnects when I restart the NAS drive or when I re...
- Oct 29, 2017
Let's put this issue to rest. The Seagate expansion drive (STAY2000102) that would disconnect from the NAS unit, has included with it a power management utility. This utility is only recognized by windows OS, so when the drive went to sleep the NAS lost communication with it and would disconnect. I could not find a program to turn this expansion power management utility off, so I removed the drive from its enclosure and installed it into a docking station connected to the NAS unit. This hard drive is functioning beautifully with the NAS unit.
Marty_M
Jun 25, 2017NETGEAR Employee Retired
Hello harryrichardfoe,
Firmware version 6.7.5 was officially release, you may want to try this version.
Welcome to the community!
Marty
NETGEAR Community Team
harryrichardfoe
Jun 30, 2017Guide
Here's the latest. Random disconnection of the Seagate USB drive has not occurred for 36 hours and has completed scheduled backups. This is what I had done, which maybe just random luck. The NAS was updated to FW 6.7.5.
The USB drive was disconnected, attached to a Windows system and formated to NTFS and chkdsk was run.
Connected the USB drive to the NAS (unfortunately at this state the USB drive would still disconnect)
Formatted the USB drive using the NAS utility to NTFS (unfortunately at this state the USB drive gave the following error on backingup: "Backup: Error backup job NAS1 Documents: destination is read-only or files/folders could not be created. Check if these files or folders meet the destination file system limitation.")
The USB drive was disconnected, attached to a Windows system and formated to NTFS and chkdsk was run again.
Connected the USB drive to the NAS and formatted using the NAS utility to EXT4.
Rebooted the NAS unit.
So far the USB drive has been accepted by the NAS unit by not randomly disconnecting and allowing backups to be performed.
So far so good.
This is the same procedure that I followed when the FW was updated from 6.5 to 6.6 to get this USB drive accepted. A bit strange the hoops that must be jumped through with these firmware updates...
