timgeorgeprice
May 25, 2017Aspirant
Re: Firmware Update to 6.7.3 Failed
Same problem - no access to device at all, can't ping, let alone SSH, nothing, never came back onto network. I'm remotely situated, so will have to take the night train to the office, but not sure wh...
- May 25, 2017
It was the full root issue. It's fixed.
Edit: If you have updated to 6.7.3 and ran into this issue please try USB Boot Recovery with ReadyNAS OS 6.7.4 which is now available!
If you have not yet upgraded please upgrade to 6.7.4 rather than 6.7.3. If your system has already been fixed I would still suggest updating to 6.7.4 the normal way using the web admin GUI.
mdgm-ntgr
May 25, 2017NETGEAR Employee Retired
Your problem may be different actually. If it's not booting at all. Most likely you've run into the mount_block_root issue some others are reporting but there's no display on the RN312 to confirm that. I'd try a power cycle and if it still has the same problem I'd suggest USB Boot Recovery.
timgeorgeprice
Thanks again - at the office now still. NAS seems to boot up (ie lights come on, though sometimes the blue power light doesn't stay on once fully booted, which seems a bad sign), however it simply grabs a DHCP address from the router for a few seconds (I see it in the router interface), then disappears again from the network. Even during the few seconds it has a DHCP address, I can't ping it or access the admin interface using the DHCP address I take from the router interface.
- mdgm-ntgrMay 25, 2017NETGEAR Employee Retired
So it doesn't show in RAIDar?
My guess would be that it's the mount_block_root error reported in some other threads. Of course the RN312 doesn't have a display on the front.- timgeorgepriceMay 25, 2017Aspirant
Got into tech support mode just now, and see the following Debug code: 53432
The DHCP address is now stable, has been there for several minutes.
Serial: 3C22330P000B6
Sorry - in answer to your question, those details come from RAIDar, so it shows fine there. Thanks.
