timgeorgeprice's avatar
May 25, 2017
Re: Firmware Update to 6.7.3 Failed
Same problem - no access to device at all, can't ping, let alone SSH, nothing, never came back onto network. I'm remotely situated, so will have to take the night train to the office, but not sure wh...
  • mdgm-ntgr's avatar
    mdgm-ntgr
    May 25, 2017
    It was the full root issue. It's fixed.
    Edit: If you have updated to 6.7.3 and ran into this issue please try USB Boot Recovery with ReadyNAS OS 6.7.4 which is now available!
    If you have not yet upgraded please upgrade to 6.7.4 rather than 6.7.3. If your system has already been fixed I would still suggest updating to 6.7.4 the normal way using the web admin GUI.
ProSupport for Business
