timgeorgeprice
May 25, 2017Aspirant
Re: Firmware Update to 6.7.3 Failed
Same problem - no access to device at all, can't ping, let alone SSH, nothing, never came back onto network. I'm remotely situated, so will have to take the night train to the office, but not sure wh...
- May 25, 2017
It was the full root issue. It's fixed.
Edit: If you have updated to 6.7.3 and ran into this issue please try USB Boot Recovery with ReadyNAS OS 6.7.4 which is now available!
If you have not yet upgraded please upgrade to 6.7.4 rather than 6.7.3. If your system has already been fixed I would still suggest updating to 6.7.4 the normal way using the web admin GUI.
timgeorgeprice
Starting an attempt at USB boot recovery.
mdgm-ntgr
May 25, 2017NETGEAR Employee Retired
- timgeorgepriceMay 25, 2017Aspirant
How can I thank you? That's miraculous! Greatly appreciated. I saw my network monitoring report the NAS pop up back on its correct IP - you're a genius!
Really wonderful work. Thanks so much!
Cheers, Tim
- zero11May 25, 2017Tutor
I have two 314's. One took the upgrade, the other did not, and is displaying lcd_panic_handler+7d Well, it was. I powered it down. What's my next step?
- mdgm-ntgrMay 25, 2017NETGEAR Employee Retired
I PM'd you zero11.
