sfpegasus
Jun 08, 2016Tutor
Format NTFS External USB Errors on Win10 machine
I use an external USB drive to backup my ReadyNas daily. It's formated NTFS (by the ReadyNas). Every now and then I need a file from the drive and I take the external drive and plug it into a Win10 ...
Jun 09, 2016Guru - Experienced User
It's odd that Windows asks to scan it. Normally the dismount in the backup job should prevent that from happening.
Have you tried telling Windows not to fix it?
sfpegasus
Jun 09, 2016Tutor
When you tell windows not to fix it, you can still access the files and folders just fine (in windows). It's when you remount it in the ReadyNas that the above error occurs.
Maybe I should format it on the windows machine?
