jtedder
Sep 18, 2015Aspirant
help with netgear 104
i have installed about 9 tb of hard space on my new nas and it only shows i have 4.53 avaliable why
jtedder
i have a4tb by wd a 3tb by wd and 2x 1 tb by wd
jtedder
oops one is a seagate 1 tb not a wd
- mdgm-ntgrSep 18, 2015NETGEAR Employee Retired
That volume capacity is correct.
If you replace one of the 1TB disks with a 4TB one you will see some expansion.
- StephenBSep 18, 2015Guru - Experienced User
That would increase the storage by 3 TB to 8 TB total (~7.3 TiB).
Your current setup wastes 1 TB on the 4 TB drive - you need at least 2 of the largest size to maximize space.
