zzymichael
Jun 15, 2017Aspirant
ISCSI disconnection issue in firmware 6.7.1 and 6.7.4
Configurations: ReadyNAS 314 used as iSCSI drive for Windows 2012 server host, and d: drive of guest VM (running Windows 2012) is using vhdx file on the iSCSI drive. Issues: iSCSI drive is disconne...
Marty_M
Aug 06, 2017NETGEAR Employee Retired
Beta firware 6.8.0 is now available and the official version will be release soon. You may want to try the beta firmware and check if it will make any difference in the behavior of the NAS. You may download the beta firmware from here.
Marty_M
NETGEAR Community Team
mangrove
Aug 06, 2017Apprentice
Marty, there are no fixes for iSCSI if one looks at the list if fixes. Why would you believe that this beta version fixes any iSCSI issues?
