zzymichael
Jun 15, 2017Aspirant
ISCSI disconnection issue in firmware 6.7.1 and 6.7.4
Configurations: ReadyNAS 314 used as iSCSI drive for Windows 2012 server host, and d: drive of guest VM (running Windows 2012) is using vhdx file on the iSCSI drive. Issues: iSCSI drive is disconne...
Marty_M
Aug 07, 2017NETGEAR Employee Retired
I understand there is no specific information on the release notes of the NAS for iSCSI, the thread is pointing to the firmware as the source of the problem. I am offering the beta firmware, if they want to try it to check if it will make any difference. If you are encountering the exact problem as the original poster and as stated on the title of the thread, you may provide us a copy of the complete logs of the NAS so we can check.
Marty_M
NETGEAR Community Team
mangrove
Aug 07, 2017Apprentice
Marty,
a sweeping recommendation to install beta quality firmware when you don't have any idea of how it will affect the issue at hand can only be called extremely unprofessional.
- AhmedTimolAug 08, 2017Aspirant
this is why this is the last netgear Piece of Rubbish NAS I ever buy in my life....
- Marty_MAug 13, 2017NETGEAR Employee Retired
Thanks for sharing the information, do you have other questions or concerns? If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solved so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Regards,
Marty_M
