geojay
Jan 15, 2020Guide
Lowest risk way to swap a drive in RN214
I currently have two 4TB drives in my NAS and would like to swap one of the drives for a new drive. What's the lowest risk way to achieve this? If I remove one of the two existing drives and replace ...
- Jan 15, 2020
Back up the data before you do it. You should have a backup plan anyway, as RAID just isn't enough to keep your data safe. The only way to do that is to have at least one copy on another device.
geojay wrote:
If I introduce the new drive in addition to the two existing drives, wait for it to sync and then remove one of the original two, what will happen?
Adding a new 4 TB drive will give you an 8 TB volume using RAID-5. Removing any drive after that will result in an 8 TB volume that is degraded (not redundant). Also, the volume would still be non-redundant while the volume is resyncing.
Hot-swapping one of the drives is the best way.
BTW, What size is the new drive? What is the reason for replacing it?
Sandshark
Jan 16, 2020Sensei
The DM series has been a bit problematic for some when used in a NAS. But mixing one "green" and one NAS-purposed drive may create new problems of it's own due to differences in spin-up times. I'd replace te other DM as soon as I had a chance, and maybe disable spin-down till then.
geojay
Jan 16, 2020Guide
Is there a better disk for use in a NAS?
- StephenBJan 16, 2020Guru - Experienced User
geojay wrote:
Is there a better disk for use in a NAS?Lots of folks here did have problems with the DM models early on - particularly the ST3000DM000. However, if yours have been running well and and are healthy, then I wouldn't be worried.
It is a good idea to monitor the SMART stats regularly, and I suggest scheduling the disk test (and the other maintenance functions) via the volume settings wheel. I run each of them every three months (spacing them out).
The best options are NAS-purposed (e.g., WD Red or Seagate Ironwolf) or Enterprise Class. Your new 4 TB Ironwolf is a good choice. I haven't seen issues with them posted here.
Sandshark: The ST4000DM000 and the ST4000NV008 have the same rotation speed (5900 rpm), so there won't be a mismatch.
