redpola's avatar
redpola
Mac OS X USB recovery drive?
So, I proudly announced to my friend how great my RN104 is. Literally as he watched it said "upgrade firmware?". I clicked yes. Foolish. Now it's hung on "booting".   I look for a fix and discover ...
  • siigna's avatar
    Nov 02, 2015
    Luckily it's pretty simple on the ARM based systems.
    Grab the USB recovery tool from here.
    Grab your firmware from here.
    Use Disk Utility to format the USB drive.
    1 partition, MS-DOS (FAT) format.
    Make sure Master Boot Record is selected under Options.
    Copy to the USB drive:
    1. The "initrd-recovery.gz" and "NTGR_USBBOOT_INFO.txt" files from the "Marvell" directory
    2. The "uImage-recovery" file from the "Marvell/RN104" directory.
    3. The firmware image.
    When you're done the layout should look like so:
    siigna@tatooine /Volumes/USBRECOVERY $ ls -al
    total 134048
    drwxrwxrwx@ 1 siigna  staff      4096 Nov  2 18:21 .
    drwxrwxrwt@ 8 root    admin       272 Nov  2 18:21 ..
    -rwxrwxrwx  1 siigna  staff         0 May 22  2013 NTGR_USBBOOT_INFO.txt
    -rwxrwxrwx  1 siigna  staff  63391744 Oct 27 11:49 ReadyNASOS-6.4.0-arm.img
    -rwxrwxrwx  1 siigna  staff   2048370 Nov 27  2014 initrd-recovery.gz
    -rwxrwxrwx  1 siigna  staff   3161676 Apr 25  2000 uImage-recovery
ProSupport for Business
