Sledge1964
Oct 19, 2015Aspirant
Management Service is Offline
Hi there - I have a Ready NAS 102. Attempted a firmware update today, but after it said 'I'll install when you restart', there was nothing. I ran RAIDar, 'Management service is offline' - so I can'...
- Oct 30, 2015
I resolved Sledge1964's issue.
Something strange happened and reset config files to blank files, so I restored default copies of those config files and restored connectivity.
JennC
Oct 20, 2015NETGEAR Employee Retired
Hello Sledge1964,
When exactly did you get the message 'I'll install when you restart"? Is that after clicking the prompt to update? Or you did the manual update and uploaded the firmware?
The links for the pictures do not work too. Please insert image of what the RAIDar shows instead.
Sledge1964
Oct 21, 2015Aspirant
That's odd - the links work for me..
I downloaded the update and installed it via the system settings menu - I did that because the auto update screwed my NAS up last time around too - I was happy I'd just got it going again, and then this happens...
So I said Update, pointed it to the correct file, it uploaded it from my PC and did its thing, then said it needs to restart.
Those are the fails and errors I can see. Raidar looks like this:
Thats what the journal looks like - repeats and repeats etc
Hope that can help you...
Thanks in advance - much appreciated.
- Sledge1964Oct 23, 2015Aspirant
Is there anybody OUT there...
- kohdeeOct 23, 2015NETGEAR Expert
Management Service is Offline is a caused by readynasd not being able to start properly.
readynasd is the main database to contain a lot of information.
OOooooooooo k. What do do?
- Jun 10, 2022Retired_Member
