Sledge1964
Oct 19, 2015Aspirant
Management Service is Offline
Hi there - I have a Ready NAS 102. Attempted a firmware update today, but after it said 'I'll install when you restart', there was nothing. I ran RAIDar, 'Management service is offline' - so I can'...
- Oct 30, 2015
I resolved Sledge1964's issue.
Something strange happened and reset config files to blank files, so I restored default copies of those config files and restored connectivity.
Sledge1964
Oct 21, 2015Aspirant
That's odd - the links work for me..
I downloaded the update and installed it via the system settings menu - I did that because the auto update screwed my NAS up last time around too - I was happy I'd just got it going again, and then this happens...
So I said Update, pointed it to the correct file, it uploaded it from my PC and did its thing, then said it needs to restart.
Those are the fails and errors I can see. Raidar looks like this:
Thats what the journal looks like - repeats and repeats etc
Hope that can help you...
Thanks in advance - much appreciated.
Sledge1964
Oct 23, 2015Aspirant
Is there anybody OUT there...
- kohdeeOct 23, 2015Administrator
Management Service is Offline is a caused by readynasd not being able to start properly.
readynasd is the main database to contain a lot of information.
- Sledge1964Oct 23, 2015Aspirant
OOooooooooo k. What do do?
- Sledge1964Oct 27, 2015Aspirant
Ok - but what can I do about it, or how do I fix that?
Cheers
- plunningOct 27, 2015Aspirant
Hi there.
having the exact same issue but in in regards to updating to 6.4.0.
- "Management Service is offline"
- Diagnostics in Raidar reports nothing odd
- Can access the shares via SMB but only for reading not writing
- Can not download logs from Raidar
Please advise !
- Jun 10, 2022Retired_Member
