Guillaume_R
Apr 21, 2020Aspirant
My RN102 is painfully slow
Hi everyone, I’ve had some difficulties using my RN102 for a long time. Transfer rates are actually more or less ok, but it’s the access times (right-click, access folders, copying a file…) that ...
Apr 21, 2020Guru - Experienced User
Guillaume_R wrote:
_I'm afraid I never consulted the logs (I don't know how to handle these). Here's a screenshot of what I get when I download them all, anything specific you want me to upload ?
Open disk_info.log in notepad. Then you can post the info here (as suggested above). Best to copy/paste into your reply (not a screenshot).
You could also search system.log for btrfs errors (just search for btrfs).
Guillaume_R wrote:
_I programmed a scrub (ie a "cleaning" right ? Not a defrag ? I have a French UI, just to make sure we understand each other ;)) every monday. I just realized it's still running right now :smileyfrustrated: Would it be the cause of my problem ?
Scrub isn't a defrag, it does other stuff. It will slow down performance when it is running (as will the balance).
Guillaume_R wrote:
_I could try the balance, you're right. Each and everytime I want to balance or test, it takes so much time I just forget it...
If the balance always takes a long time, then you probably need to run them more often. Scrubs generally take about the same amount of time, but the balance will run quite quickly if there isn't anything it needs to do.
Guillaume_R wrote:
Speaking of that, is there any way I can test/map my whole home network, so that I can determine where is located the flaw ?
One aspect here is that SMB isn't very efficient at folder browsing (and that appears to be the performance issue that bothers you the most). So if there are a lot of files in your folders, you might need to re-organize them into subfolders, which would help.
But first we should rule out the network and the NAS itself. You can test with NAStester, it would give us some better idea of the large file speeds you are seeing. http://www.808.dk/?code-csharp-nas-performance
Guillaume_R
Stephen, here we go for disk_info :
Device: sda
Controller: 0
Channel: 0
Model: WDC WD30EFRX-68EUZN0
Serial: WD-WMC4N2537953
Firmware: 80.00A80W
Class: SATA
RPM: 5400
Sectors: 5860533168
Pool: data
PoolType: RAID 1
PoolState: 1
PoolHostId: e35da80
Health data
ATA Error Count: 0
Reallocated Sectors: 0
Reallocation Events: 0
Spin Retry Count: 0
Current Pending Sector Count: 0
Uncorrectable Sector Count: 0
Temperature: 31
Start/Stop Count: 416
Power-On Hours: 44047
Power Cycle Count: 416
Load Cycle Count: 365
Device: sdb
Controller: 0
Channel: 1
Serial: WD-WCC4N1LF9UVX
Firmware: 82.00A82W
Class: SATA
RPM: 5400
Sectors: 5860533168
Pool: data
PoolType: RAID 1
PoolState: 1
PoolHostId: e35da80
Health data
ATA Error Count: 0
Spin Retry Count: 0
Temperature: 31
Start/Stop Count: 384
Power-On Hours: 29376
Power Cycle Count: 384
Load Cycle Count: 457
In the system.log, there appears to be no btrfs error.
Using NAS perf tester, I got these on my 3 partitions :
NAS performance tester 1.7 http://www.808.dk/?nastester
Running warmup...
Running a 400MB file write on A: 5 times...
Iteration 1: 10,68 MB/sec
Iteration 2: 10,35 MB/sec
Iteration 3: 10,02 MB/sec
Iteration 4: 10,30 MB/sec
Iteration 5: 10,15 MB/sec
Average (W): 10,30 MB/sec
Running a 400MB file read on A: 5 times...
Iteration 1: 7,14 MB/sec
Iteration 2: 7,18 MB/sec
Iteration 3: 7,05 MB/sec
Iteration 4: 7,09 MB/sec
Iteration 5: 7,11 MB/sec
Average (R): 7,11 MB/sec
Running warmup...
Running a 400MB file write on X: 5 times...
Iteration 1: 10,13 MB/sec
Iteration 2: 10,68 MB/sec
Iteration 3: 10,58 MB/sec
Iteration 4: 10,53 MB/sec
Iteration 5: 10,52 MB/sec
Average (W): 10,49 MB/sec
Running a 400MB file read on X: 5 times...
Iteration 1: 7,18 MB/sec
Iteration 2: 7,10 MB/sec
Iteration 3: 6,89 MB/sec
Iteration 4: 7,08 MB/sec
Iteration 5: 6,95 MB/sec
Average (R): 7,04 MB/sec
Running warmup...
Running a 400MB file write on Y: 5 times...
Iteration 1: 12,05 MB/sec
Iteration 2: 12,15 MB/sec
Iteration 3: 11,48 MB/sec
Iteration 4: 11,51 MB/sec
Iteration 5: 12,01 MB/sec
Average (W): 11,84 MB/sec
Running a 400MB file read on Y: 5 times...
Iteration 1: 7,23 MB/sec
Iteration 2: 7,46 MB/sec
Iteration 3: 7,28 MB/sec
Iteration 4: 7,22 MB/sec
Iteration 5: 7,33 MB/sec
Average (R): 7,30 MB/sec
I just stopped the scrub process, to see what happens. I set it to run when I was away at work, but now I'm forced to work from home, so I spend a lot of time on the computer. I guess I should have thought about that earlier...
