powellandy1
Dec 02, 2020Virtuoso
Onedrive Backup Failure
Hi Struggling to get Onedrive backup set up (upload only). RN422 with 6.10.3. Set it up a couple of times (as pictured below) Repeatedly fails. Log shows: Dec 02 21:29:29 Backup ng-c...
- Dec 10, 2020
The dot (little "light") in the icon turns blue when the NAS is backing up the files.
Could you please follow this https://kb.netgear.com/25625/How-do-I-send-ReadyNAS-system-logs-to-NETGEAR-Support to download the system logs and then send it to me in a private message?
B_L
Dec 06, 2020NETGEAR Expert
Let's check if it is related to speed limit. Please disable the upload speed limit and see if it helps.
powellandy1
Dec 10, 2020Virtuoso
It does. On unlimited it works - but the internet grinds to a halt. It seems to go completely full pelt without saving a small % of bandwidth - which makes it pretty unusable except overnight.
Once I put a limit (I've tried 50KB/s and 150KB/s - my broadband upload is about 2Mb/s - so limiting to about half) in it seems to hang after an hour or two and the little 'light' turns from green to blue.
Bug in the throttling code??
- B_LDec 10, 2020NETGEAR Expert
- powellandy1Dec 19, 2020Virtuoso
Just to close this off. B_L kindly reviewed logs, found a bug, patched NAS remotely and all working fine.
