kevin_marchant
Oct 22, 2015Aspirant
OS 6.4.0 - ReadyNAS 316 - Front Panel Lights Permenantly On - Anyone else ?
Since upgrading from 6.2.4 to 6.4.0, the front panel lights on my 316 have been set to permenantly on / high brightness and the panel is unresponsive to touch input. I've tried the workaround used o...
- Oct 27, 2015
Hello kevin_marchant,
I don't see him actively answering in the community lately but you can try sending PM to him.
Or you can also try contacting support center to have them check your NAS.
JennC
Oct 23, 2015NETGEAR Employee Retired
I believe this result occurred on one of the BETA 6.4 versions.
Other than LEDs problem, are you getting any other problem after the update to 6.4.0? Can you still access the shares and the admin page?
kevin_marchant
Oct 27, 2015Aspirant
Yes, other than the front panel, the box works as expected (admin, shares, timemachine).
I have two 316's purchased May '13 and Jan '15, both running 6.4.0
The front panel on the older one works fine. The problem is only with the newer one (different revision of motherboard ?)
The problem occurs everytime from a cold start.
I can reliably clear the problem on the newer one if I do a "reboot".
So yes, I'm hopeful it's not a hardware problem and as you suggest a firmware problem
Shall I contact Skywalker directly or can you ask him to PM me? He may recall I helped out with some slow file copy problems in 6.1.9
Kevin
- JennCOct 27, 2015NETGEAR Employee Retired
- xcom923Nov 20, 2015Aspirant
I wouldn't call this "solved" I have the same problem. It's clearly a firmware issue. I didn't have this problem before I updated the firmware to 6.4. But then again I didn't have it but for a day before I updated the firmware
- kevin_marchantNov 20, 2015Aspirant
Thanks, glad to know I'm not alone.
You're right - it isn't solved, but I've been PMing with Skywalker and we've done some initial tests, so from the point of view of this forum there is little other superficial advise (reset to factory defaults) that would help.
I have two 316's bought 18 months apart, which I reckon has resulted in different motherboard revisions - the newer one bought in Jan this year. The older one bought May 13 behaving itself.
I can reset the front-panel into operation by SSHing into the box after it has been up for a couple of minutes and issuing the following
echo 1 > /sys/bus/i2c/devices/*/reinitial
Sometimes it works instantaneously when you get the command prompt back, sometimes it takes a couple of minutes even after returning to the command prompt. It seems to be far more effective after a "restart" rather than just after power up. I've resorted to simply leaving the box on all the time.
Haven't heard from Skywalker in a couple of weeks now - he must be a busy man.
