Ironman991
Jun 08, 2021Follower
R.E: NAS Serial NONE0002
Can someone please help me out, I have this issue: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/Incorrect-serial-no-on-ReadyNas-6-Pro-can-t-access-ReadyCloud/td-p/1922633
- Jun 09, 2021
Hi Ironman991,
The fix has been applied. The serial number should appear correctly now.
JohnCM_S
Jun 08, 2021NETGEAR Employee Retired
Hi Ironman991,
Welcome to the Community!
Please take a picture of the sticker label that contains the serial number and MAC address, then send it to me via private message. This is located on the rear panel of the chassis.
Please enable also the Secure Diagnostic Mode (SDM). You can enable it by logging in to the local admin page of the NAS then go to System > Settings > Support, then send the 5-digit code/port number to me.
- JohnCM_SJun 09, 2021NETGEAR Employee Retired
Hi Ironman991,
