RDenben
Dec 12, 2014Aspirant
Re-Syncing
Thank you for the help yesterday with my boot problem. It is partially fixed. Now, there is a new issues. The machine now boots with one disk; but the blue power light pulsates (two quick blin...
RDenben
Dec 13, 2014Aspirant
No, it wasn't duped. It was copied from the smart_history file.
The disk that is currently in the NAS is in bay #2. Should I place this in bay #1 and then place the other disk in #2? I would prefer not to wipe these disks. Does resyncing wipe data?
Thanks
Thanks
