BSMorgan
Dec 11, 2025Aspirant
ReadNAS Pro 6 stuck on 'ReadyNAS' when booting
My ReadyNAS Pro6 isn't booting and is stuck on the logo. I have tried the reset button but I don't even think it is getting to that point. I am about to go through and disconnect and reconnect as m...
- Dec 12, 2025
BSMorgan wrote:
Any tips on that sort of swap would also be appreciated.
Start with a test install using a single disk in slot 1. This disk will be reformatted, so make sure there is nothing on it that you care about. No need to worry about the compatibility list, any SATA disk will work for this.
After you've confirmed that the test install worked, then power down the NAS and move the disk to slot 2. Power up, and confirm that the system boots with the disk in the slot. Repeat this process for slots 3-6.
Then update the firmware to match what you are running in the old NAS. If you aren't sure, then just install the newest firmware. That would be 4.2.31 unless you converted the NAS to run OS-6.
Once the firmware matches, then power down again, and migrate your existing disks to the new NAS.
When the new NAS is up and running, then you could consider replacing the power supply and using it as a backup NAS. If you decide to sell it for parts instead, then I suggest selling the drive trays (with the screws) separately.
Sandshark
Dec 12, 2025Sensei
There are actually a multitude of things that can cause that, as the "ReadyNAS" message is stored in the display and the NAS just needs +5V (and not very well regulated +5V) to display that. But StephenB is correct that the power supply is the most common. I've bought (and then repaired and resold) several with that symptom, and only one in the 6 I bought had something wrong other than the PSU.
The 6-bay legacy units (Pro and Ultra 6 models) actually have a standard pin-out and a standard ATX supply can be used externally with no pin-out modification. If you have one available (even if you need to temporarily "borrow" it from a working PC), you can quickly find if that's the issue doing that. If you use an external supply for a long period (if you just want to get your files and then plan to ditch the NAS, for example), then make sure you take precautions to insure the fan moves enough air over the drives. Cover the PSU fan hole and any gaps where the cable comes out with masking tape.
A standard SFX supply will work as an internal replacement, but most need a 24-pin extension and more 4-pin MOLEX connectors. While the original is 250W, it has more +12V wattage than most 250W, so I recommend at least a 350W one.
While it used to be a bit cheaper to buy a standard supply and add those features to it, there is a pre-modified one available on eBay that now has a price that's about what it would cost to do it yourself and is a whole lot easier.
If it's not the power supply, there isn't a lot more that's user serviceable. RAM and the CPU are it. A bad CPU is rare, but bad RAM is a possibility.
