BSMorgan
Dec 11, 2025Aspirant
ReadNAS Pro 6 stuck on 'ReadyNAS' when booting
My ReadyNAS Pro6 isn't booting and is stuck on the logo. I have tried the reset button but I don't even think it is getting to that point. I am about to go through and disconnect and reconnect as m...
- Dec 12, 2025
BSMorgan wrote:
Any tips on that sort of swap would also be appreciated.
Start with a test install using a single disk in slot 1. This disk will be reformatted, so make sure there is nothing on it that you care about. No need to worry about the compatibility list, any SATA disk will work for this.
After you've confirmed that the test install worked, then power down the NAS and move the disk to slot 2. Power up, and confirm that the system boots with the disk in the slot. Repeat this process for slots 3-6.
Then update the firmware to match what you are running in the old NAS. If you aren't sure, then just install the newest firmware. That would be 4.2.31 unless you converted the NAS to run OS-6.
Once the firmware matches, then power down again, and migrate your existing disks to the new NAS.
When the new NAS is up and running, then you could consider replacing the power supply and using it as a backup NAS. If you decide to sell it for parts instead, then I suggest selling the drive trays (with the screws) separately.
BSMorgan
Thanks for your response. Any recommendation for a 6-bay USB chassis that you might be familiar with?
Sandshark
Dec 12, 2025Sensei
Make sure it's not one with internal RAID capability. Even where RAID can be turned off, most with that capability don't work because they don't actually give "raw" access to the drives.
Another option for recovery is to make images of your drives and mount them in a virtual machine, either a ReadyNAS VM or a Linux one. See Mounting-ReadyNAS-drives-in-a-virtual-NAS-for-data-access.
- BSMorganDec 12, 2025Aspirant
Thank you. I actually found a Pro 6 chassis on ebay for not too much so I and going to go that route. Any tips on that sort of swap would also be appreciated. This thing has basically run like a champ for 14 years. I think I have had 1 drive go out but that's been the only issue.
- StephenBDec 12, 2025Guru - Experienced User
- BSMorganDec 21, 2025Aspirant
Thanks for the help so far. I have done what you said up to the point of putting all 6 of my original disks into the new unit. Want to make sure that I am understanding correctly that the unit will see their volume and open it correctly as long as the disks are in correct order. Right?
