oliver1994chapp
Jul 27, 2020Aspirant
re ready Nass ultra 2
i have install 6.9.5 on ultra 2 but the admin page is not workiong and its got an ip 192.168.10.100 and is sysc the volume. and its doing it aging from oliver
Sandshark
Jul 27, 2020Sensei
Did you also upgrade the RAM to 2GB? I've not heard of specific issues due to insufficient RAM before OS6.10.x, but you're going to need it soon.
If the Ultra2 is still syncing, GUI access may be adversly affected. The Ultra series have fairly poor performing processors by today's standards, so that kind of multi-tasking may be asking a lot (especially if also with limited memory).
Do you have a specific issue with the IP address?
- oliver1994chappJul 27, 2020Aspirant
hi
we did a reinstall of the os6 and now that is working
but only dis is 1tb but only showing 459 there
does it resize by in self or do we something like run this commund
btrfs filesystem resize max /data
how to we run this if we need to
from oliver
- StephenBJul 27, 2020Guru - Experienced User
Is the volume still syncing? Can you post a screenshot of the volume page?
- oliver1994chappJul 28, 2020Aspirant
Please find screen shot enclosed
As you can see bay 1 is 1tb and bay 2 is 500gb
Volume as you can see is showing 458.95 free ?
How do you get the volume to show the correct amount (1tb in bay 1 and 500gb in bay 2 ) ?
Does it add the 2 drives together to make one total ?
When using it does it put on either disc or does it fill one first ?
Thanks Martin / Oliver
