oliver1994chapp
Jul 27, 2020Aspirant
re ready Nass ultra 2
i have install 6.9.5 on ultra 2 but the admin page is not workiong and its got an ip 192.168.10.100 and is sysc the volume. and its doing it aging from oliver
oliver1994chapp
hi
we did a reinstall of the os6 and now that is working
but only dis is 1tb but only showing 459 there
does it resize by in self or do we something like run this commund
btrfs filesystem resize max /data
how to we run this if we need to
from oliver
Jul 27, 2020Guru - Experienced User
Is the volume still syncing? Can you post a screenshot of the volume page?
- oliver1994chappJul 28, 2020Aspirant
Please find screen shot enclosed
As you can see bay 1 is 1tb and bay 2 is 500gb
Volume as you can see is showing 458.95 free ?
How do you get the volume to show the correct amount (1tb in bay 1 and 500gb in bay 2 ) ?
Does it add the 2 drives together to make one total ?
When using it does it put on either disc or does it fill one first ?
Thanks Martin / Oliver
- StephenBJul 28, 2020Guru - Experienced User
Your NAS is using RAID-1 - as you can see from the screenshot next to the volume wheel. RAID-1 mirrors the disks - everything written to one is simultaneously written to the other. That gives you some protection against a disk failure, and also allows you to expand the volume size later on without data loss.
Since they are mirrored, the volume size can't be bigger than smallest disk - 500 GB in you case.
Personally I think that RAID-1 is the best mode for most users. If you want to keep it, you should get two 2 TB drives (perhaps Seagate Ironwolf models). Using both would give you 2 TB of storage. Alternatively, get one Ironwolf to start, and just use one disk in the NAS now. Then add a second matching disk later on (as budget permits). A single Ironwolf 2 TB drive costs about $80 (current US pricing).
The other option is to set up the disks to be independent - using one volume for each disk. This mode is called "jbod". You'd need to
- change to flexraid by clicking on the XRAID control in your screen shot. The green stripe on the control will disappear
- destroy the current volume (click on the volume settings wheel)
- click on the first drive in the center graphic and create a jbod volume
- click on the second drive in the center graphic, and create a second jbod volume.
Then you need to put some shares on each disk. You don't want a volume to get more than about 85% full, so you want to set up the shares with that in mind.
- oliver1994chappJul 29, 2020Aspirant
Dear
Just to say a big thank you for helping us out with the ReadyNas.
We set it up with your second option (jbod) as I found another disc which was 2TB its speed was approx 5400 rpm and the 1TB speed was 7200rpm I found out after warning that they did not mix well with mirroring so I thought jbob was best for us.
Find screen shot enclosed
Once again Thank You
Martin/Oliver
