tipster71
Oct 27, 2015Guide
ReadyNAS 104 system hanging frequently after 6.4.0 upgrade
Hi All, I have a pretty new ReadyNAS 104 system (August, 2015). Currently populated with 3 x 4TB WD RED drives, and a single Segate 3TB drive (to be upgraded once funds allow). Since upgrading to...
ViciousPariah
Oct 29, 2015Aspirant
Thanks JennC,
Been following that thread as well. Not sure I want to try the downgrade just yet, but have followed through with the deletion of the snapshots, and other ideas. Still problematic. Waiting to do a full factory default to see if that will fix everything. Hopefully there'll be a 6.4.1 soon which fixes all these nagging problems.
- JennCOct 29, 2015NETGEAR Employee Retired
Hello ViciousPariah,
FW downgrade is not possible on 6.4.0. If you can back up the files before factory reset, please do.
You may also try to contact support center.
