R800MON
Jan 09, 2019Aspirant
Readynas 422 Rsync error
I have an issue with two of my existing Backups which i am unable to resolve. The host is a Readynas 422 and the remote nas is also a 422.
The only that has changed recently in my setup is a update...
Jan 09, 2019Guru - Experienced User
You appear to be backing up over the ReadyCloud VPN - is that the case?
R800MON
No I sync my document files and folders via Readycloud over VPN, the backup is via Rsync.
- StephenBJan 10, 2019Guru - Experienced User
5.69.1.178 is in the backup entry you posted, and it appears to be a ReadyCloud VPN address. It's hard to be certain, since Netgear is hijacking 5.x.x.x addresses for ReadyCloud (these used to be assigned for experimental use, but were reclaimed by IANA when IPv4 addresses started running out).
Can you confirm that 5.69.1.178 is the correct internet IP address of the destination? It appears to be hosted by skybroadband.com.
- R800MONJan 10, 2019Aspirant
Yes this is the correct IP address.
It is rather unusual to see a static address and not a ddns name as the backup destination for an off-site NAS. FWIW, rsync over ssh is a more secure backup choice for over-the-internet backups since it is encrypted.
One option is to downgrade back to 6.9.3 and see if the backups start working again.
If all backups going to the remote 422 are failing, I'd also check the port forwarding on the remote system, and make sure that the local NAS IP address hasn't changed.
