debumitra
Apr 09, 2022Tutor
ReadyNAS 424 front USB port stopped working
Hello, I have a ReadyNAS RN424 whose front USB port stopped working. I know this because no portable disk connected to the front port is recognized by the RN424 anymore; although the same ones conne...
- Apr 11, 2022
debumitra wrote:
Will all these settings move to the new box simply by transferring the disks?
If yes, is this possible because these configurations or settings are saved on the disks and not in some non-volatile memory installed in the NAS enclosure?
All settings/configuration files are stored in a 4 GB OS partition that is mirrored on every disk - and the NAS boots from that partition.
So migrating is simply a matter of moving your disks to the new NAS (ideally preserving slot order) and powering it on.
The NAS does have keep the most recently installed OS image in its flash. When you migrate, the NAS will check the OS version in the flash with what is on the disks. If the flash is newer, it will update the firmware on the disks from the flash. If the flash is older, then it update the flash from the disks. There are some other steps needed when the new NAS is a different model, to update the hardware configs.
Since in your case the NAS is still running, you might want to upgrade to the newest firmware (6.10.7 at the moment) before migrating. That would eliminate the chance that the new NAS would upgrade firmware during the first boot.
Apr 11, 2022Guru - Experienced User
debumitra
Apr 17, 2022Tutor
StephenB,
I received the replacement NAS from Netgear in record time and was able to set it up without any trouble. The information you provided was extremely helpful and improved my understanding.
The replacement came with OS 6.10.1. But my NAS was already on 6.10.7. But at the first boot, the replacement NAS found 6.10.7 on the disk and updated it, as you prescribed.
My NAS had a static MAC-to-IP set up. So I changed that to the replacement NAS' MAC-to-IP before I connected and powered the replacement NAS on. That was the only additional step I had to really do.
I shall keep an eye on the new one for a couple of days before returning the old one to Netgear. Again, I very much appreciate the help I got.
Thank you.
- StephenBApr 17, 2022Guru - Experienced User
I'm glad the RMA worked out, and that your migration went smoothly.
