kevcompton
Sep 08, 2015Apprentice
ReadyNAS 516 with EDA500 Expansion unit issue when started from timer.
Hi, When the ReadyNAS 516 and EDA500 is automatically started from a set timer sometimes but not always, the follow messages are output and the share on the EDA500 is unavailable: Disk in channe...
JennC
Sep 11, 2015NETGEAR Employee Retired
Hello kevcompton,
The RESYNC to ONLINE messages I believe is normal.
Since you mentioned there is/are share/s that is unavailable, does this mean you have multiple volumes? What's the RAID level?
kevcompton
Sep 11, 2015Apprentice
Hi,
Thanks for responding, i've added screen shots of when EDA1 is successful mounted. When not, the eda1 volume is shown in red and the only option from that screen is to format the drives. As I said, a reboot fixes this. Since posting, I have had 1 occasion where the eda1 volume is unavailable after a manual boot.
Also, I only get the RESYNC to ONLINE messages when there is an issue.
Hope you can help.
Will add a screen shot when it fails again if that helps.
Kevin.
