kevcompton
Sep 08, 2015Apprentice
ReadyNAS 516 with EDA500 Expansion unit issue when started from timer.
Hi, When the ReadyNAS 516 and EDA500 is automatically started from a set timer sometimes but not always, the follow messages are output and the share on the EDA500 is unavailable: Disk in channe...
Sep 14, 2015Guru - Experienced User
kevcompton wrote:
...I have saved the logs but can't see a way of uploading them here...
You don't. You can email logs to Netgear if you have a support case (or if a Netgear person here is interested). mdgm has the details in his signature links.
kevcompton
Sep 14, 2015Apprentice
Thanks. Do you suggest that I should open a support case for this then?
- StephenBSep 14, 2015Guru - Experienced User
If this was purchased after June 1 2014 then you should have free lifetime chat support for this NAS, so I would open a case on this.
Netgear folks engaged here (mdgm, jennc, etc) might also be interested in the logs.
A good way to proceed is open the case, post the case number on this thread, and then email the logs. Perhaps include a link to this thread in the email.
Then Netgear will be able to tie the case to this thread.
