kevcompton
Sep 08, 2015Apprentice
ReadyNAS 516 with EDA500 Expansion unit issue when started from timer.
Hi, When the ReadyNAS 516 and EDA500 is automatically started from a set timer sometimes but not always, the follow messages are output and the share on the EDA500 is unavailable: Disk in channe...
JennC
Sep 15, 2015NETGEAR Employee Retired
Hello kevcompton,
I checked your profile and found that you have several legacy ReadyNAS units. This ReadyNAS 516 is not yet registered, this should have free support.
I think your case is for L3 escalation, please contact support center.
kevcompton
Sep 16, 2015Apprentice
Thanks.
I recently updated the firmware to the latest beta and the issue hasn't happened again.
If it does, I will contact support.
- JennCSep 17, 2015NETGEAR Employee Retired
Hello kevcompton,
In case BETA resolves the issue, please let us know. You may also post it at ReadyNAS OS6 BETA release board.
- inspectorgadjetJan 20, 2016Apprentice
I'm experiencing the same issue with my EDA500. My readynas also sometimes just gets stuck saying booting and I have to power both the nas and expansion chassis off completely and then when I power on again they are fine.
I have a 314 and this happens about once a week. I am on OS 6.4.1.
- mdgm-ntgrJan 21, 2016NETGEAR Employee Retired
Perhaps you could see if ReadyNASOS 6.4.2 (RC1) also resolves the problem for you?
Can you send me your logs (see the Sending Logs link in my sig)?
