steveoelliott
Jul 21, 2018Luminary
ReadyNAS 526 Unclean Shutdown
Hi all, Today one of my ReadyNAS 526's was uncleanly shutdown due to an error on my part... The unit was idle at the time and has come back online but I am keen to understand how an unclean shutdown ...
- Jul 21, 2018
The file system itself is designed to handle unclean shutdown cleanly (with no need for file system checking).
The software raid underneath is generally a bigger concern, as lost writes can result in a RAID array that is out of sync. If it does fall out of sync, the volume won't be mounted (so that definitely didn't happen in your case). The RAID sync vulnerability isn't filesystem dependent - it's the same with ext3 as it is with btrfs.
Jul 21, 2018Guru - Experienced User
There are event counters on each disk, which mdadm uses to detect if the array is in sync. There is a command option (--force) which tells mdadm to ignore the counters. If you use that, then the array will mount, but there will be some volume corruption (since there are lost writes).
steveoelliott wrote:
is it a feature limitation of the implementation?
I think the possibility of lost writes as a result of an unexpected shutdown (or crash) is inherent to RAID. I always recommend using a UPS with a NAS, as that eliminates the possibility of an unexpected power cut. Though of course a crash can create the same effect. Disabling the write cache is another way to substantially reduce the risk (with a performance cost) - though write cache controls aren't available in the current web ui.
steveoelliott
Jul 23, 2018Luminary
Thanks Stephen.
I do use UPS's on all my devices. However, on this occasion the device was uncleanly shutdown due to an error on my part :)
- StephenBJul 23, 2018Guru - Experienced User
Been there, done that :smileyfrustrated:
