davidr1
Sep 11, 2016Luminary
ReadyNAS Diagnostic error
OS 6.5.1 2 x WD RED 1TB drives Hi Just did a diagnostics on my Ultra - errors were shown so I did a defrag. The result was: Successfully completed diagnostics System Logs 2016-09-12 09:5...
davidr1
Sep 14, 2016Luminary
Many thanks for the replies,
I only run Linux (Ubuntu).
Raidar says it is up to date on 6.1, NAS OS is now 6.5.2 (was 6.5.1 on first post)
mdgm wrote:You won't get a segfault error when checking diagnostics on 6.6.0.
I assume that is OS 6.0 when released?
mdgm wrote:Have you run a read-only filesystem check of the filesystem on the USB disk?
Ran it through gparted - I'm Linux only.
I'll do it through the command line. Thanks BrianL, but I don't have Windows. Seatools might be an option.
Any ideas if and how I can remove the journals the error messages refer to?
Much appreciate your help.
David
BrianL2
Sep 14, 2016NETGEAR Employee Retired
Hi davidr1,
I am not sure how but let me check it with my colleagues and get back to you.
Kind regards,
BrianL
NETGEAR Community Team
