DaveEJH
Jun 16, 2020Aspirant
ReadyNAS Duo RND2000 V2 and Mac "Time Machine"
Would my ReadyNAS Duo RND2000 V2 be suitable for Mac Catalina "Time Machine" backups? Perhaps by letting Time Machine reformat? Not sure of the current ReadyNAS firmware version! Contains 2 x...
Jun 16, 2020Guru - Experienced User
DaveEJH wrote:
On the front: "ReadyNAS Duo"
On the underside label it has printed: "NETGEAR ReadyNAS Duo RND2000 v2"
As I said, the labeling is confusing. You have the original Duo (called a v1 here). That other label means you have hardware revision 2 of the Duo v1. The Duo was launched in 2008, and Netgear stopped shipping it on late 2011.
Your Duo will be running 4.1.x firmware. The current version is 4.1.16 - if you are running something older you should update it.
One challenge with the Duo (either version) is that they are limited to SMB v1. That will create issues accessing network shares from both Windows 10 and (I think) Catalina. It's easy to re-enable SMB v1 in Windows - not sure what it takes with Catalina.
DaveEJH
Stephen . . . Thanks again. At least now I have a starting point. I'll still report back . . . but no holding your breath as I'm rather busy at the moment.
Much appreciated - Dave H.
