BriMill
Sep 24, 2018Tutor
ReadyNAS Duo V2/Logitech Media Server/RAIDiator v5.3.13
Hi,
Note to Netgear - your product support is so poor you're less likely to win returning customers than syphilis!
Before I bin the painfully dire contraption that is the ReadyNAS Duo V2 I th...
- Sep 24, 2018
Well, use internet explorer....
Mine works and i did exactly as i wrote abobe.
// Hans
viperhansa
Sep 24, 2018Virtuoso
Yeah, just remember... do NOT use chrome... if you do you get an error....
Use IE or try whatever.. I use IE..
