SthFitz
Aug 12, 2012Follower
ReadyNAS Duo won't boot after 4.1.9 upgrade- #19121497
My ReadNAS Duo V1 has been turned into a virtual boat anchor after doing a standard upgrade to OS 4.1.9. I can't see it on RAIDar 4.3.4, I can't access it on Windows Explorer (Windows 7-64) although ...
Rabbie
Aug 23, 2012Aspirant
First, If you configue the correct "Alert", the logs would send to you. You also can check the disk status in page "status"-"Health".
The second, bad disk will caused the system boot failed. System will check all disks when booting.
The last, It is no related with firmware 4.1.9. You can check the disk with disk vendor's tool. No firmware can caused fine disk to bad disk physical.
