b4pjoe
Sep 01, 2015Aspirant
ReadyNAS Duo won't boot
Info on bottom says RND2110v2. I bought this unit used a couple of years ago and it worked fine until about 6 months ago and it would not start up. I suspected a power brick issue but at the time...
Sep 02, 2015Guru - Experienced User
They are the only instructions I know about, and they say "duo/nv+/1100". Maybe someone from Netgear can chime in, and say how to handle the case where there is no LCD.
b4pjoe
Sep 02, 2015Aspirant
Oops! Well I guess I should have looked at the manual...in it it says:
"Press the Power button and continue to press it for 20 seconds; release after all Disk LEDs flash 4 times."
