b4pjoe
Sep 01, 2015Aspirant
ReadyNAS Duo won't boot
Info on bottom says RND2110v2. I bought this unit used a couple of years ago and it worked fine until about 6 months ago and it would not start up. I suspected a power brick issue but at the time...
Sep 02, 2015Guru - Experienced User
Sounds like you should wait for the new disks before doing anything rash.
b4pjoe
Sep 02, 2015Aspirant
Yeah I am going to but I think I will try to find a new power brick to try. I really don't think the drives are spinning up.
- b4pjoeSep 03, 2015Aspirant
New disks arrived today. No help. Still the same flashing lights. Another power supply on the way is my last gasp effort.
- b4pjoeSep 09, 2015Aspirant
New disks, two new power supplies. Still same old flashing light results. Tried every way possible options to boot different ways. Nothing works. Unit is toast it seems.
