robert002
May 07, 2022Aspirant
readynas duo2000 cat not boot after firmware upgrade
[background] when i got one ReadyNAS Duo 2000 v1, the firmware version is 4.1.7, and then i upgrade to 4.1.16, because there is no SSH, so i decide to downgrade to 4.1.3(I think there must has ssh i...
Sandshark
May 10, 2022Sensei
It sounds like you need to do a USB recovery to 4.1.16, but a little more investigation to confirm is recommended if you have data not backed up that you need to recover, as suggested by StephenB .
robert002
May 11, 2022Aspirant
Hi Sandshark:
Thanks! no data need to backup. can you show me the USB recovery way. i tried but faild. not sure if i do it correctly.
btw, if USB recovery failed, if there is other way to rescue..
