robert002
May 07, 2022Aspirant
readynas duo2000 cat not boot after firmware upgrade
[background] when i got one ReadyNAS Duo 2000 v1, the firmware version is 4.1.7, and then i upgrade to 4.1.16, because there is no SSH, so i decide to downgrade to 4.1.3(I think there must has ssh i...
Sandshark
May 12, 2022Sensei
Try to find a USB flash with an access LED so you can see it it's being accessed at all. It is possible that something else happened completely independent of the firmware update/downgrades, but it seems unlikely. Do you know that the front USB port was working before all this? That could certainly complicate things.
robert002
May 17, 2022Aspirant
the front USB port is wokring good before. but i think it looks the problem before booting from USB drive. because when i power on (no matter how i press and hold reset buttor or press and hold power butter), no LED at all, it seems it does not go to USB booting step.
