Lestrad
Jun 06, 2016Aspirant
ReadyNAS NV+ Fails to Power Up after Power Failure
After a power outage that lasted a day and a half, my ReadyNAS NV+ won't power up. Should I assume the problem is the power supply and that it's just a coincidence that it died just when there was an...
- Jun 06, 2016
Hi Lestrad,
Have you tried using other power outlet(s) or power cord(s)? If ever you have already tried it, then I advise you to open an online case with NETGEAR Support. State what happened to your NAS and the troubleshooting steps we did to isolate the problem. A replacement power supply for your NAS might be process for you.
Check this article below as reference on how to replace the power supply unit of your ReadyNAS NV+:
ReadyNAS Replacement PSU guide
DaneA
NETGEAR Community Team
DaneA
Jun 06, 2016NETGEAR Employee Retired
Hi Lestrad,
Use a CAT5e ethernet cable to connect the LAN port of the NAS to the LAN port of your PC.
DaneA
Lestrad
Okay, did that, but it still won't power on.
- DaneAJun 06, 2016NETGEAR Employee Retired
Hi Lestrad,
DaneA
- StephenBJun 06, 2016Guru - Experienced User
Likely you have a PSU failure, but it is sensible to try another outlet.
You can also pull the disks (labeling them by slot) and see if the NAS powers up. It can't boot, but you will see life on the LCD panel ("no disks"), etc.
Even if the warranty is no longer valid (and it is usually 5 years on the NV+), some units had a service action and are eligible for a free PSU replacement even if they are out of warranty. Definitely worth calling support to see if they can help you.
- LestradJun 15, 2016Aspirant
It was indeed a PSU failure. I took your very good advice and messaged them via the site, and they got authorization to send me a new PSU (I don't know if my unit comes under the service action). It arrived in a couple of days at zero cost to me. They did explain that since my unit is out of warranty (since November 2015), I shouldn't expect another such gesture. But how could I complain? The whole experience confirms my conviction that Netgear is a serious outfit that respects its products and their users, which is more than you can say for many.
On a side note, while I had it apart I went ahead and replaced the standard fan with a Noctua NF A9 FLX, using the middle noise setting, and when I pushed the power button I was sure the unit was still dead until I looked at the LCD and saw it was booting (which it did, and also re-synchronized, without a hitch). That's how quiet the fan is. RAIDar reports the temperature as being good, although I can't give precise figures.
Thanks to everybody for their help, and thanks to Netgear. I'm a happy camper.
Product: ReadyNASRND4000
Serial Number: 23J3027700C11
Country of Purchase: UK- BrianL2Jun 16, 2016NETGEAR Employee Retired
Hi Lestrad,
We appreciate your feedback and for letting us know that your unit is back online. We look forward to hearing more from you in the future.
Kind regards,
BrianL
