Lestrad
Jun 11, 2019Aspirant
ReadyNAS nv+ won't power up after outage. Power Supply Problems?
Hello My ReadyNAS NV+ (Product: ReadyNASRND4000, Serial Number: 23J3027700C11) was originally purchased in November 2010. In June 2016 I had a problem with the power supply: The NAS wouldn't start u...
- Jul 09, 2019
Yup. You can test that it turns on the supply with it disconnected before you do it with it connected. You'll know the supply came on because the fan will run.
If it works, you likely won't want to leave it that way, but it's a way to get the data off the NAS.
Jun 19, 2019Guru - Experienced User
Lestrad wrote:<<Did you test it under load?>>
Uh, no.
The net is - you can tell if a supply is bad if you test it with no load, but you can't be certain it is good.
I haven't done a load test, but I think one way is to get a 24 pin splitter cable (https://www.amazon.com/Splitter-Hamkot-Adapter-Motherboard-Extension/dp/B074DQJY8K ). That would let you use the NAS as the load, and test the voltages using the meter on the unused half of the splitter.
Lestrad
Jun 19, 2019Aspirant
Thanks!
The only problem is that the NAS won't start up at all - the fan doesn't even come on. So it's not pulling any load.
I'm willing to go to some lengths to make sure it isn't the PSU. The only way I can see is either to try in a NAS that is known to work or else buy a new PSU and try it, and if it doesn't work send it back.
Any suggestions are welcome.
PS Just to clear up one point: Why a 24-pin splitter cable? The NAS uses a 20-pin connector.
- StephenBJun 19, 2019Guru - Experienced User
Yes, it should have been 20 pin. But I'm not seeing a 20 pin splitter.
Do you have a spare ATX supply? If so, you could jury-rig that to work (keeping it outside the chassis with a longer extension cable).
- SandsharkJun 20, 2019Sensei
It's fairly easy to modify a 24-pin to 20+4 pin ATX extender/adapter to power the NV+ from an ATX supply. It's more than just using the adapter, though, you need to swap some pins.
- LestradJun 20, 2019Aspirant
Thanks! I've found a few threads relating to how to do the adaptation of the 24-pin ATX PSU connector. Is there one you recommend?
Thanks again for your help.
Les
