Lestrad
Jun 11, 2019Aspirant
ReadyNAS nv+ won't power up after outage. Power Supply Problems?
Hello My ReadyNAS NV+ (Product: ReadyNASRND4000, Serial Number: 23J3027700C11) was originally purchased in November 2010. In June 2016 I had a problem with the power supply: The NAS wouldn't start u...
- Jul 09, 2019
Yup. You can test that it turns on the supply with it disconnected before you do it with it connected. You'll know the supply came on because the fan will run.
If it works, you likely won't want to leave it that way, but it's a way to get the data off the NAS.
Sandshark
Jun 20, 2019Sensei
It's fairly easy to modify a 24-pin to 20+4 pin ATX extender/adapter to power the NV+ from an ATX supply. It's more than just using the adapter, though, you need to swap some pins.
Lestrad
Jun 20, 2019Aspirant
Thanks! I've found a few threads relating to how to do the adaptation of the 24-pin ATX PSU connector. Is there one you recommend?
Thanks again for your help.
Les
