vaprasad
Oct 11, 2022Aspirant
ReadyNAS Pro 6 running OS 6.10.8 Volume Missing?
Pro 6 running ReadyNAS OS 6.10.8 with RAID 6. Unable to access any of my shares. Web indicates "No volumes exist. NETGEAR recommends that you create a volume before configuring other settings. Na...
Dec 10, 2022Guru - Experienced User
vaprasad wrote:
Never heard back from the mods on the what could be found.
Marc_V and JeraldM - did you get the PM? If so, did you see anything in the logs?
Marc_V
Dec 12, 2022NETGEAR Employee Retired
Apologies for the delayed response it seems that my PM did not reach you properly.
This issue happened after the upgrade to 6.10.8 and I only found BTRFS errors that affected the mounting of your volume. If you have backup, you can opt to restore the volume by re-initializing the NAS and restore data from backup. However, this is not the case so I think a Data recovery service would be needed. I will send another PM as well.
Thanks StephenB for the mention
HTH
