SteveMathews
Nov 20, 2016Guide
ReadyNAS Pro 6 stuck at Booting...
Help! For a few days now my Pro 6 has been hanging on the boot screen at about 5% complete. Prior to this it has been stable for the last 3 months and hapily uploading/ synchronising to the A...
- Nov 22, 2016
SteveMathews wrote:
if these are any help
Not really, ls -i shows the inode for each file, but it doesn't give you the number of inodes used.
If you use dlna, then go into /var/cache and delete the contents of the dlna cache folder.
Then perhaps just try booting again.
Nov 22, 2016Guru - Experienced User
It is still quite full - mine runs at ~40% full with Crashplan installed.
Check the inode usage also (df . -i)
SteveMathews
Nov 22, 2016Guide
when i run df -i it returns
df: invalid operation --i
does this mean the coreutils is not up to date?
i'm very rusty with linux so i'll need to look up some navigation commands before i go hunting around for the space-wasting files.
do you know where i'm likley to find the log files (most likely for amazon cloud sync) (and how to navigate there!)
thanks again
Steve
