chainlinc
Aug 28, 2018Guide
ReadyNAS Pro 6 volume loss after resync
I
1) I went on vacation from 2018-08-13 until 2018-08-25, upon my return, the (OS: 6.9.3, BIOS: Flame6-MB 2010-07-26) ReadyNAS Pro 6 NAS (protected by a 1500VA UPS) was inaccessible. Upon reboo...
mdgm-ntgr
Aug 28, 2018NETGEAR Employee Retired
Can you download your logs and send them in please (see the Sending Logs link in my sig)?
- chainlincAug 29, 2018Guide
The logs have been sent.
- mdgm-ntgrAug 29, 2018NETGEAR Employee Retired
This is a data recovery situation. From kernel.log we see.
Aug 28 15:06:47 rnpro kernel: Btrfs loaded, crc32c=crc32c-generic Aug 28 15:06:47 rnpro kernel: BTRFS: device label 540ed803:root devid 1 transid 1169013 /dev/md0 Aug 28 15:06:47 rnpro kernel: BTRFS info (device md0): has skinny extents Aug 28 15:06:49 rnpro kernel: BTRFS: device label 540ed803:data devid 1 transid 361746 /dev/md127 Aug 28 15:06:49 rnpro kernel: BTRFS info (device md127): has skinny extents Aug 28 15:06:49 rnpro kernel: BTRFS critical (device md127): corrupt node, bad key order: block=794230784, root=1, slot=309 Aug 28 15:06:49 rnpro kernel: BTRFS critical (device md127): corrupt node, bad key order: block=794230784, root=1, slot=309 Aug 28 15:06:49 rnpro kernel: BTRFS error (device md127): failed to read block groups: -5 Aug 28 15:06:49 rnpro kernel: BTRFS critical (device md127): corrupt node, bad key order: block=794230784, root=1, slot=309 Aug 28 15:06:49 rnpro kernel: BTRFS critical (device md127): corrupt node, bad key order: block=794230784, root=1, slot=309 Aug 28 15:06:49 rnpro kernel: BTRFS error (device md127): failed to read block groups: -5 Aug 28 15:06:49 rnpro kernel: BTRFS error (device md127): parent transid verify failed on 793083904 wanted 361745 found 361747 Aug 28 15:06:49 rnpro kernel: BTRFS error (device md127): parent transid verify failed on 793083904 wanted 361745 found 361747 Aug 28 15:06:49 rnpro kernel: BTRFS error (device md127): parent transid verify failed on 793444352 wanted 361744 found 361747 Aug 28 15:06:49 rnpro kernel: BTRFS error (device md127): parent transid verify failed on 793444352 wanted 361744 found 361747 Aug 28 15:06:49 rnpro kernel: BTRFS warning (device md127): failed to read tree root Aug 28 15:06:49 rnpro kernel: BTRFS error (device md127): parent transid verify failed on 792395776 wanted 361743 found 361745 Aug 28 15:06:49 rnpro kernel: BTRFS error (device md127): parent transid verify failed on 792395776 wanted 361743 found 361745 Aug 28 15:06:49 rnpro kernel: BTRFS warning (device md127): failed to read tree root Aug 28 15:06:49 rnpro kernel: BTRFS error (device md127): open_ctree failed Aug 28 15:11:06 rnpro kernel: BTRFS info (device md127): has skinny extents Aug 28 15:11:06 rnpro kernel: BTRFS critical (device md127): corrupt node, bad key order: block=794230784, root=1, slot=309 Aug 28 15:11:06 rnpro kernel: BTRFS critical (device md127): corrupt node, bad key order: block=794230784, root=1, slot=309 Aug 28 15:11:07 rnpro kernel: BTRFS error (device md127): failed to read block groups: -5 Aug 28 15:11:07 rnpro kernel: BTRFS critical (device md127): corrupt node, bad key order: block=794230784, root=1, slot=309 Aug 28 15:11:07 rnpro kernel: BTRFS critical (device md127): corrupt node, bad key order: block=794230784, root=1, slot=309 Aug 28 15:11:07 rnpro kernel: BTRFS error (device md127): failed to read block groups: -5 Aug 28 15:11:07 rnpro kernel: BTRFS error (device md127): parent transid verify failed on 793083904 wanted 361745 found 361747 Aug 28 15:11:07 rnpro kernel: BTRFS error (device md127): parent transid verify failed on 793083904 wanted 361745 found 361747 Aug 28 15:11:07 rnpro kernel: BTRFS error (device md127): parent transid verify failed on 793444352 wanted 361744 found 361747 Aug 28 15:11:07 rnpro kernel: BTRFS error (device md127): parent transid verify failed on 793444352 wanted 361744 found 361747 Aug 28 15:11:07 rnpro kernel: BTRFS warning (device md127): failed to read tree root Aug 28 15:11:07 rnpro kernel: BTRFS error (device md127): parent transid verify failed on 792395776 wanted 361743 found 361745 Aug 28 15:11:07 rnpro kernel: BTRFS error (device md127): parent transid verify failed on 792395776 wanted 361743 found 361745 Aug 28 15:11:07 rnpro kernel: BTRFS warning (device md127): failed to read tree root Aug 28 15:11:07 rnpro kernel: BTRFS error (device md127): open_ctree failed Aug 28 15:23:02 rnpro kernel: BTRFS info (device md127): has skinny extents Aug 28 15:23:02 rnpro kernel: BTRFS critical (device md127): corrupt node, bad key order: block=794230784, root=1, slot=309 Aug 28 15:23:02 rnpro kernel: BTRFS critical (device md127): corrupt node, bad key order: block=794230784, root=1, slot=309 Aug 28 15:23:02 rnpro kernel: BTRFS error (device md127): failed to read block groups: -5 Aug 28 15:23:03 rnpro kernel: BTRFS critical (device md127): corrupt node, bad key order: block=794230784, root=1, slot=309 Aug 28 15:23:03 rnpro kernel: BTRFS critical (device md127): corrupt node, bad key order: block=794230784, root=1, slot=309 Aug 28 15:23:03 rnpro kernel: BTRFS error (device md127): failed to read block groups: -5 Aug 28 15:23:03 rnpro kernel: BTRFS error (device md127): parent transid verify failed on 793083904 wanted 361745 found 361747 Aug 28 15:23:03 rnpro kernel: BTRFS error (device md127): parent transid verify failed on 793083904 wanted 361745 found 361747 Aug 28 15:23:03 rnpro kernel: BTRFS error (device md127): parent transid verify failed on 793444352 wanted 361744 found 361747 Aug 28 15:23:03 rnpro kernel: BTRFS error (device md127): parent transid verify failed on 793444352 wanted 361744 found 361747 Aug 28 15:23:03 rnpro kernel: BTRFS warning (device md127): failed to read tree root Aug 28 15:23:03 rnpro kernel: BTRFS error (device md127): parent transid verify failed on 792395776 wanted 361743 found 361745 Aug 28 15:23:03 rnpro kernel: BTRFS error (device md127): parent transid verify failed on 792395776 wanted 361743 found 361745 Aug 28 15:23:03 rnpro kernel: BTRFS warning (device md127): failed to read tree root Aug 28 15:23:03 rnpro kernel: BTRFS error (device md127): open_ctree failed Aug 29 09:36:23 rnpro kernel: Btrfs loaded, crc32c=crc32c-generic Aug 29 09:36:23 rnpro kernel: BTRFS: device label 540ed803:root devid 1 transid 1169102 /dev/md0 Aug 29 09:36:23 rnpro kernel: BTRFS info (device md0): has skinny extents Aug 29 09:36:24 rnpro kernel: BTRFS: device label 540ed803:data devid 1 transid 361746 /dev/md127 Aug 29 09:36:24 rnpro kernel: BTRFS info (device md127): has skinny extents Aug 29 09:36:25 rnpro kernel: BTRFS critical (device md127): corrupt node, bad key order: block=794230784, root=1, slot=309 Aug 29 09:36:25 rnpro kernel: BTRFS critical (device md127): corrupt node, bad key order: block=794230784, root=1, slot=309 Aug 29 09:36:25 rnpro kernel: BTRFS error (device md127): failed to read block groups: -5 Aug 29 09:36:25 rnpro kernel: BTRFS critical (device md127): corrupt node, bad key order: block=794230784, root=1, slot=309 Aug 29 09:36:25 rnpro kernel: BTRFS critical (device md127): corrupt node, bad key order: block=794230784, root=1, slot=309 Aug 29 09:36:25 rnpro kernel: BTRFS error (device md127): failed to read block groups: -5 Aug 29 09:36:25 rnpro kernel: BTRFS error (device md127): parent transid verify failed on 793083904 wanted 361745 found 361747 Aug 29 09:36:25 rnpro kernel: BTRFS error (device md127): parent transid verify failed on 793083904 wanted 361745 found 361747 Aug 29 09:36:25 rnpro kernel: BTRFS error (device md127): parent transid verify failed on 793444352 wanted 361744 found 361747 Aug 29 09:36:25 rnpro kernel: BTRFS error (device md127): parent transid verify failed on 793444352 wanted 361744 found 361747 Aug 29 09:36:25 rnpro kernel: BTRFS warning (device md127): failed to read tree root Aug 29 09:36:25 rnpro kernel: BTRFS error (device md127): parent transid verify failed on 792395776 wanted 361743 found 361745 Aug 29 09:36:25 rnpro kernel: BTRFS error (device md127): parent transid verify failed on 792395776 wanted 361743 found 361745 Aug 29 09:36:25 rnpro kernel: BTRFS warning (device md127): failed to read tree root Aug 29 09:36:25 rnpro kernel: BTRFS error (device md127): open_ctree failed
