Wystell
Apr 18, 2018Aspirant
ReadyNas RND4000 NV+ V2 stuck booting
I have a ReadyNas RND4000-200NAS NV+ V2 which has 4 disks (2x3TB Seagate NAS Drive, 2x750GB Seagate drives) and was configured using XRaid I believe. The NAS was running the most recent version of Ra...
AMER31
Jul 13, 2018Aspirant
I have same sort of issue, when disks are present take long time to boot and error message displayed Disk Partitioning Error, If I reboot with out disks error message No Disk detected.
Can ping the NAS but admin page is not accessable at all
Can do telnet
try to re-install OS but no good
Please help I have lot of data on the NAS
- StephenBJul 14, 2018Guru - Experienced User
I think the next step is to power down the NAS and test the disks in a Windows PC using vendor tools (seatools for seagate, lifeguard for western digital). Disks can be connected either with SATA or a USB adapter/dock.
If you are booting diskless, than that is expected. The boot flash doesn't include a web interface.
AMER31 wrote:
Can do telnet
This is with disks installed, and using tech support mode?
Did you try this using the front panel, or from telnet?
- AMER31Jul 14, 2018Aspirant
StephenB Thanks I will try to test these 3 x disks is there any otherway to test if READYNAS is ok
StephenB Ok I never knew that
@AMER31 wrote:
Can do telnet
StephenB Yes I looked at the enclosure logs and can see that disk 2 has some issues what do you suggest chnage the disk ?
disk!!1!!status=not_present
disk!!2!!status=ok::descr=Channel 2: ST2000DM001, 3 GB; ATA Error Count: 2
disk!!3!!status=ok::descr=Channel 3: SAMSUNG HD204UI, 1863 GB
disk!!4!!status=ok::descr=Channel 4: ST2000DM001-1CH164, 1863 GB
model!!0!!mode=home::descr=ReadyNAS NV+ v2::arch=arm1::jbod=1@AMER31 wrote:
StephenB tried from the front panel
- StephenBJul 15, 2018Guru - Experienced User
Two ATA errors sounds healthy to me, though it is still worth running seatools on all the disks.
AMER31 wrote:
Forgot to mention that still admin page is not accessable
I think the first goal is to extract any data on the NAS, so you have a full backup of the contents. Without a backup, we need to be more cautious. Do you have data you need to extract?
If you have access via SMB, etc you could simply do a drag/drop of all the files to external storage.
